Can Bluno M3's 5V ICSP header connect to 5V SPI devices like Pixy?
JaneYu 2024-07-11 03:15:12 567 Views0 Replies Would this microcontroller connect to SPI devices whose operation voltage is 5V using ICSP? e.g. Pixy I noticed on your wiki for the Bluno M3 that you mention not to use any 5 V sensors, so I assume this will be incompatible. But, there is also mention of the 5 V ICSP Arduino compatible header.
2024-07-11 03:15:12 Yes, it is the only way to use SPI devices (5V, operation voltage) through ICSP header.
JaneYu
JaneYu
