APC220 module connection fails when RF-magic software is open
JaneYu 2024-07-11 12:41:23 502 Views0 Replies Why I can not connect the APC220 module after I opened the RF-magic software on my Window/Linux?
2024-07-11 12:41:23 If you are using Mac or Linux, please note: 1) Linux: The current on the 'En' pin of adapter is different when using the USB-Serial board on Linux. The same issue happens on Mac. The solution is to not connect the En pin, using a cable, or a handmade breakout board. 2) Windows (64-bit OS): You should set the RF-Magic program's compatibility to "windows XP (Service pack 3)" and "run this program as administrator"
JaneYu
JaneYu
