UPS power priority: 5.5x2.1mm DC vs USB-C when both connected?
userHead JaneYu 2024-07-11 08:08:17 674 Views0 Replies
If both the 5.5x2.1mm DC and USB TypeC power supplies are connected to the UPS, which power source will the system prioritize?
2024-07-11 08:08:17 The system will prioritize the power source with the higher voltage. The USB Type-C PD will automatically negotiate to supply 20V, while the voltage through the 5.5x2.1mm DC port will depend on the specifications of the power adapter used. userHeadPic JaneYu
