Any reasons for no output or output errors
userHead JaneYu 2024-07-11 04:57:07 627 Views0 Replies
2025-07-24 15:28:12
1. The sensor is a precision device. Please do not disassemble it by yourself when using it to avoid damage to the product.
2. If the reading value is 0, check whether there is a light source and whether the product protective cover is removed.
3. The 485 bus is disconnected, or the A and B lines are connected in reverse.
4. Check whether the power supply meets the marking.
