When uploading, there is always an upload project error. why?
userHead JaneYu 2024-07-11 18:22:28 451 Views0 Replies
2024-07-11 18:22:28 Generally, when uploading a project, it should be in the case of power failure; if the power switch has been turned off and you still failed to upload project, then you should check if the serial port is connected. userHeadPic JaneYu
