Why does Max deviate from the map when he makes a turn in line-tacking?
JaneYu 2024-07-11 20:20:25 419 Views0 Replies Why does Max deviate from the map when he makes a turn in line-tacking?
2024-07-11 20:20:25 All of the line-tracking program associated with Max are tested with sufficient power. If Max is in a state of deviation in the course of the line-tracking, it indicates that the power is not sufficient, as a result, the spinning speed of the wheels is not enough. Now you need to adjust the speed of two wheels by replacing the battery.
JaneYu
JaneYu
