Built-in temp sensor? How to enable compensation?
userHead JaneYu 2024-07-11 20:07:57 751 Views0 Replies
Does this sensor have a temperature sensor? How to make the temperature compensation?
2024-07-11 20:07:57 This TDS probe has no temperature sensor, but the temperature compensation algorithm is reserved in the sample code. The temperature variable in the sample code will default to 25 °C without a temperature sensor. You can add a waterproof temperature sensor to read the temperature,then update the temperature variable, to make automatic temperature compensation. userHeadPic JaneYu
