If the module is not working properly, plz check
JaneYu 2024-07-11 10:27:48 535 Views0 Replies If the module is not working properly, plz check
2025-07-24 16:05:10
JaneYu
①SIM card should be in service
② Switches should in right position
③ The external power supply should be 7-12V@2A
④ Check signal range, best to be on an area with full coverage.
⑤ Signal for GPS has best performance on a clear direct line of sight with sky, even better with less buildings around.
⑥ GPS needs time to connect to at least 4 satellites to output data.
JaneYu
