DF, how long does the probe need to be calibrated?
userHead JaneYu 2024-07-11 23:02:34 3806 Views0 Replies
2024-07-11 23:02:34 The calibration interval is determined by the frequency of use. Normally, you can calibrate it once a month. If used frequently, it can be calibrated once a week. When calibrating, fresh standard buffer solution is recommended. userHeadPic JaneYu
