why does first calibration always fail?
userHead JaneYu 2024-07-11 02:45:46 635 Views0 Replies
Hello DFRobot, during the first calibration, the calibration always failed. What could be the reason?
2025-07-24 16:06:51
When calibrating, the relevant parameters are stored in the specified position in EEPROM. If other data previously saved in the same position in EEPROM, there may be a conflict, resulting in an inability to calibrate properly. Use the following code to erase the contents in the specified position in EEPROM. Run it once, then upload the sample code again to restart the calibration.
This code will reset the corresponding EEPROM used by DFRobot Gravity EC Meter K=1. SKU:DFR0300
When uploaded this code, please open the serial monitor of the Ardino IDE. The correct value of the EEPROM block should be 255.
#include <EEPROM.h>
#define ECADDR 0x0A
Serial.begin(115200);
for(int i = 0;i < 8; i++ )
EEPROM.write(ECADDR+i, 0xFF);// write defaullt value to the EEPROM
delay(10);
static int a = 0, value = 0;
value = EEPROM.read(ECADDR+a);
Serial.print(ECADDR+a,HEX);
Serial.print(":");
Serial.print(value);// print the new value of EEPROM block used by EC meter. The correct is 255.
Serial.println();
delay(10);
a = a + 1;
if (a == 8)
while(1);
