I can't debug via COM port without OTG plugged.
JaneYu 2024-07-11 17:11:23 577 Views0 Replies I can't debug via COM port without OTG plugged.
2024-07-11 17:11:23 Internal Edison will detect the value of "VBUS" pin, and it doesn't permit debugging while "VBUS" is LOW. It means you need connect a OTG cable to OTG port.(It doesn't need to connect anything to OTG cable), when you want to debug Edison via the COM port.
JaneYu
JaneYu
