How to accuracy control the flow rate?
userHead JaneYu 2024-07-11 11:16:17 644 Views0 Replies
2024-07-11 11:16:17 It is better to make a calibration before usage, you can put the pump in the water, get power, and calculate the time it fill up the cylinder, Then, you will know the flow rate in each second. userHeadPic JaneYu
