Can't upload with XBee in Prog mode - expansion board issue?
userHead JaneYu 2024-07-11 10:22:55 613 Views0 Replies
I inserted an xbee module on the expansion board, then switched the extension board to Prog, but it still failed to upload, how to solve it?
2024-07-11 10:22:55 It may be that the power of xbee module is too high, usb power supply cannot offer enough power. You can try to add a lithium battery power supply to the mainboard. userHeadPic JaneYu
