What's the sensor output unit and LUX conversion method?
JaneYu 2024-07-11 04:05:55 605 Views0 Replies What's the sensor output unit and LUX conversion method?
2025-07-24 16:08:24
JaneYu
Well, it is only a simple analog sensor that could show you the ** of the light intensity (within its detect range) and voltage (0-5V). If you want to transfer the voltage to unit in LUX, then well, it requires that you have a commercial Light Intensity Meter like this that can display LUX info, then you can match the readings to the sensor's analog reading, then you could a map to describe the ** of voltage and ambient light density.
JaneYu
