Can Arduino with Relay Shield v2.1 read XBee digital I/O? Is a logic level converter needed?
userHead Schultz.Langley 2024-07-25 11:08:55 880 Views1 Replies
With your relay shield v2.1 is it possible for the Arduino to read the status of some of the digital I/O pins of an XBee? Because the XBee is 3.3 volt there would need to be a logic level converter on the board, I believe.
2025-07-25 11:12:07
It is OK. 3.3V will be recognized as high level.
userHeadPic Schultz.Langley
