I cannot power on the Antbo.
JaneYu 2025-07-25 11:12:03 643 Views1 Replies I cannot power on the Antbo.
2025-07-25 11:16:59
JaneYu
1. Try to power antbo via the onboard USB port. After that, touch the mental part for more than 3 seconds on the head part. The two LEDs should be on. It insures that the electronic part is properly worked.
NOTE: The USB connecter cannot power the legs. It can only power other electronic parts.
2. Try using your phone or pad to connect the antbo. The app should normally invoke a firmware update. After updating, both the LED will be on.
JaneYu
