ESP32 DEVKIT v1 with C1001
userHead Angelo.Mainente 2025-08-07 17:31:14 1093 Views3 Replies
I tyred the esp32 devkit v1 with C1001 ,  i has correct the code with #include "DFRobot_HumanDetection.h"
#define RXD1 16  // RX2
#define TXD1 17  // TX2
DFRobot_HumanDetection hu(&Serial1);
  Serial.begin(115200);  // Per monitor seriale
  Serial1.begin(115200, SERIAL_8N1, RXD1, TXD1);  // Seconda seriale su GPIO16 (RX), GPIO17 (TX)
but the output serial is :
mode:DIO, clock div:1
load:0x3fff0030,len:4744
load:0x40078000,len:15672
load:0x40080400,len:3152
entry 0x4008059c
Start initialization
Initialization successful
Start switching work mode
error!!!
error!!!
error!!!
error!!!
error!!!
error!!!
error!!!
error!!!
2026-08-02 21:46:22
how to connect all the pins of c1001 to esp32 ?
userHeadPic refael
2025-08-07 19:58:27
I finally solved it. The c1001 must be powered by the ESP32 and not by an external power supply.
userHeadPic Angelo.Mainente
2025-08-07 17:50:10
