UNIHIKER™ K10. When I use the AI blocks, the screen flickers but doesn't respond
Proves.Equips 2025-08-14 02:00:46 2438 Views6 Replies Hi, can anyone help me?
My facial recognition and the cat and dog recognition aren't working. When I use the AI blocks, the screen flickers but doesn't respond.
Hello, I tested your code on my K10 and did not encounter any screen flickering issues.
Could you please send us a video of the screen flickering and your DFRobot order number to our email address so that we can investigate the issue with your K10 in detail?
If we determine that it is a hardware issue and your product is under warranty, we will provide you with the after-sales service.
Our email address is:
unihiker@dfrobot.com
Yeez_B Hello,
I've already sent you the video and information about purchasing the device.
I look forward to your response.
Thank you very much.
Best regards.
I received a new replacement board free of charge, and it works perfectly.
Thank you so much for resolving the issue.
Good to know that, have fun with the Unihiker.
Can you attach a screenshot of your code?
Yeez_B Hello,
It doesn't work with any program. I reset the motherboard as indicated here,
https://www.unihiker.com/wiki/K10/GettingStarted/gettingstarted_mindplus/
but the restore program doesn't work either. In the FAQ, I've considered the errors that could be generated by using a card, and the frequency of calls to the AI algorithm.
I attach a screenshot of the program, but simply using the detection block no longer works, the screen restarts, flashing white.
Thank you so much.
