How to. Df player connect
userHead Rioolvis 2025-08-22 11:52:14 954 Views2 Replies
 I just have a question. I trie to connect a df player to a batteryholder and i have reed contacts n/o and  n/c.
I want to play a track when i disconnect the magnets.
The dfplayer needs to stop planning after the track and needs to stop playing when the magnets are together again.
I know for you guys this maybe is a simple question but i am a rookie with Electronics ..
Can you please tell me where i must connect all then wires so that it will work.
2025-08-29 11:35:54
I can relate to your struggle with connecting electronics, as I had a similar experience when I first began exploring DIY projects. The trial and error process can be daunting, but it's also quite rewarding when everything finally works. When I was trying to set up an audio system, I had to consult various resources and forums for help. Connecting components correctly can be confusing at first, but eventually, you’ll gain confidence as you keep practicing. If you're looking for some entertainment while taking a break, I recommend checking out [url=https://sprunkii.io]**[/url] for some fun ideas.
userHeadPic Joel.Ride
2025-08-22 11:58:31
What reedcontact do i need and is it possible anyway?
I treedt several options but it never works the way i want it. It must stop when the magnets are back or when the track is over.
userHeadPic Rioolvis
