UNIHIKER K10 temperature + humidity correction needed
to.dae 2025-09-01 06:12:10 1168 Views2 Replies after appr. 5 minutes the K10 seems to get warm as the values of Temp&Humi Sensor(AHT20) are appr. 5°C temperature too much and 15% humidity too less. are there any more precise values to work with than these quick observations? it makes the AHT20 quite unreliable.
thank you. started something like this but was wondering if there is anything already out there as the manufacturer should be aware of his construction and may be interested in use-cases that dont just use the sensors as random generators.
to.dae Put the K10 in normal operating position. Place the AHT20 where it normally sits.
If possible, place a reference sensor 50–100 mm away or outside the K10 (this provides true ambient).
Start logging: power on K10 and begin recording at t=0 (timestamp each sample).
Continue logging for 30–60 minutes. If you can, do a second run after cooling to ambient to check repeatability.
Save the log to CSV for analysis.
ahsrab.rifat
