Old UNIHIKER wirh new Mind+
Geppy57 2025-09-10 16:39:29 2362 Views3 Replies Hi all.
I try to connect online my UNIHIKER (not K10) with new Mind+ V1.8.1 RC3.0, but when I try to select UNIHIKER on expansion I found only the K10 model.
Later I try to connect online the device, but nothing happens on connection.
The device doesn't appear on reachable devices
I can solve this issue?
2025-09-15 10:00:17
Yeez_B
If you are using the M10, the Unihiker M10 is in the python mode instead of the offline mode.
M10 Mind+ tutorial:
https://www.unihiker.com/wiki/GettingStarted/gettingstarted_mindplus/
Yeez_B Geppy57
wrote:
2025-09-18 00:14:10 1 Replies
Yes. My fault. Tks
2025-09-11 01:48:57
ahsrab.rifat
Update your Mind+ installation to v1.8.1 RC1.0 (or later). This version explicitly added K10 support and the corresponding “UNIHIKER” extension block.
https://mindplus.dfrobot.com/ReleaseLogs
https://www.unihiker.com/wiki/K10/get-started/
ahsrab.rifat
