How does GNSS-RTK Kit Base Station use to establish its absolute location? (SKU: KIT0198-US)
Doug.Paradis 2025-09-16 22:41:41 1529 Views1 Replies The GNSS-RTK kit (SKU: KIT0198-US) will show different locations between starts when both base and mobile units have not been moved. This is most likely due to the base station having no “known” absolute location.
1. How does the base station determine absolute location?
a) Automomous GNSS averaging? If so how many data points are used in the averaging? Can the number of data points be changed? Can continous averaging be used?
b) Initial RTK fix? If using this method, is there a way to continue to use additional fixs to improve estimate of absolute location?
c) Some other method? What is the method?
2. Is it possible to access the base station software? If so, how?
HI. I am also using the GNSS-RTK kit. were you able to resolve you startup position issue?
I also need the base station location to be fixed.
I also wondered if you have found any other resources for this product. I mean, it works, but there are a lot of details that aren't covered in the DFRobotics docs…
Thanks. Phil.
MD USA
Philip.Malone
