mmwave - READING which of four separate distance ranges?
Protohaven Marty 2025-09-18 07:26:16 1271 Views1 Replies Hi! I have a question about the mmwave radar products.
My project is to detect the level of fullness in a barrel of sawdust. I see that the Arduino library provides the ability for me to set up to four distance detected ranges. Is there a mechanism in the existing Arduino library to read -which- of the four ranges the object is in? (In my use case, four levels of fullness.)
So far, in the API function list I only see the means to detect in one range. [ bool readPresenceDetection(void); ]
TIA for any advice. If any of your other products are better suited for my needs, I am entirely open to that possibility.
In a PERFECT world, it would be great to get the distance-to-target as some kind of continuous reading - percentage of the specified range, or floating point distance in meters. Is there any possibility of this?
Protohaven Marty
