SEN0676 80-GHz radar sensor - Measuring cycle
Janos.Wenzl 2025-09-25 22:00:46 1271 Views1 Replies What would be the max measuring rate I could achieve with the SEN0676 80-GHz radar sensor? I'm struggling to find any information on that online or in the datasheet.
2025-09-26 23:03:50
ahsrab.rifat
There’s no explicit “max measuring rate” listed for the SEN0676 in the datasheet/wiki but in practice you should expect about 1 reading/s (≈1 Hz) as a reliable, conservative figure when using the UART/Modbus interface. Some 80 GHz FMCW level sensors from other vendors advertise update rates “≤1 s” or RS-485 update ≈1 Hz (and 4–20 mA outputs sometimes 1–3 Hz).
ahsrab.rifat
.jpg)
