TroubleshootingArduino
Resolved: Reading raw data from MAX30102 V2
userHead Thanks_For_Any_Help 2025-10-16 03:52:46 2137 Views1 Replies
I am trying to read data from the MAX30102 V2 Dfrobot PPG sensor SEN0344 using an Arduino Mega, using I2C, however; I am having no success so far. I really appreciate any help you can give, and even your time just looking at this, thanks so much in advance.
I have wired it as shown below(left MAX30102, Right Arduino Mega)
3V3 → 3.3V
GND → GND
SCL → SCL
SDA → SDA
When I try to run the following code on the Arduino Mega(taken from the examples page on the DFRobot github)  it simply outputs: MAX30102 was not found.
n.b. Question Continued after code
 * @file basicRead.ino
 * @brief Output readings of red light and IR
 * @n This library supports mainboards: ESP8266, FireBeetle-M0, UNO, ESP32, Leonardo, Mega2560
 * @copyright  Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
 * @licence     The MIT License (MIT)
 * @author [YeHangYu](hangyu.ye@dfrobot.com)
 * @version  V0.1
 * @date  2020-05-29
 * @url https://github.com/DFRobot/DFRobot_MAX30102
#include <DFRobot_MAX30102.h>
DFRobot_MAX30102 particleSensor;
Macro definition opions in sensor configuration
sampleAverage: SAMPLEAVG_1 SAMPLEAVG_2 SAMPLEAVG_4
               SAMPLEAVG_8 SAMPLEAVG_16 SAMPLEAVG_32
ledMode:       MODE_REDONLY  MODE_RED_IR  MODE_MULTILED
sampleRate:    PULSEWIDTH_69 PULSEWIDTH_118 PULSEWIDTH_215 PULSEWIDTH_411
pulseWidth:    SAMPLERATE_50 SAMPLERATE_100 SAMPLERATE_200 SAMPLERATE_400
               SAMPLERATE_800 SAMPLERATE_1000 SAMPLERATE_1600 SAMPLERATE_3200
adcRange:      ADCRANGE_2048 ADCRANGE_4096 ADCRANGE_8192 ADCRANGE_16384
  //Init serial
  Serial.begin(115200);
   *@brief Init sensor
   *@param pWire IIC bus pointer object and construction device, can both pass or not pass parameters (Wire in default)
   *@param i2cAddr Chip IIC address (0x57 in default)
   *@return true or false
  while (!particleSensor.begin()) {
    Serial.println("MAX30102 was not found");
    delay(1000);
   *@brief Use macro definition to configure sensor
   *@param ledBrightness LED brightness, default value: 0x1F(6.4mA), Range: 0~255(0=Off, 255=50mA)
   *@param sampleAverage Average multiple samples then draw once, reduce data throughput, default 4 samples average
   *@param ledMode LED mode, default to use red light and IR at the same time
   *@param sampleRate Sampling rate, default 400 samples every second
   *@param pulseWidth Pulse width: the longer the pulse width, the wider the detection range. Default to be Max range
   *@param adcRange Measurement Range, default 4096 (nA), 15.63(pA) per LSB
  particleSensor.sensorConfiguration(/*ledBrightness=*/0x1F, /*sampleAverage=*/SAMPLEAVG_4, \
                                  /*ledMode=*/MODE_MULTILED, /*sampleRate=*/SAMPLERATE_400, \
                                  /*pulseWidth=*/PULSEWIDTH_411, /*adcRange=*/ADCRANGE_4096);
  //Print result
  Serial.print("R=");
   *@brief Get red value
   *@return Red light reading
  Serial.print(particleSensor.getRed());
  Serial.print(" IR=");
   *@brief Get IR value
   *@return IR reading
  Serial.print(particleSensor.getIR());
  Serial.println();
  delay(100);
Since this was not working I tried running simple I2C scanner code, recieving the result: Scanning I2C bus...
I2C device found at 0x57  !
Scan complete
#include <Wire.h>
  Wire.begin();  // Join I2C bus as master
  delay(1000);   // Wait for serial monitor to open
  Serial.println("Scanning I2C bus...");
  byte error, address;
  int nDevices = 0;
  for(address = 1; address < 127; address++ ) {
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0) {
      Serial.print("I2C device found at 0x");
      if (address < 16) Serial.print("0");
      Serial.print(address, HEX);
      Serial.println("  !");
      nDevices++;
    else if (error == 4) {
      Serial.print("Unknown error at address 0x");
      Serial.println(address, HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
  else
    Serial.println("Scan complete\n");
  delay(2000); // Wait 2 seconds before next scan
Since I had found the I2C address was available I tried to find the part ID to verify that the sensor was functioning. The result I got was:
Testing MAX30102 Part ID...
Read register 0xFF = 0xFF
As the result should be 0x15, does this mean there is something wrong with the PPG sensor, have I wired it wrong? I'm very happy to give more information and I really appreciate any help of any kind.
2025-10-17 18:47:02
Resolved:
- The issue is that the Library i am using is designed for MAX30102 V1, rather than the V2 I am using, as the V2 incorporates an MCU you cannot access raw data with it.- you can only use the DFRobot_BloodOxygen_S.h with V2.
userHeadPic Thanks_For_Any_Help
