SEN0539 Can "You're welcome to use the voice recognition assistant" be disabled?
userHead Bob S. 2025-10-31 08:21:02 628 Views0 Replies
I would like to use the SEN0539 voice recognition module so that I can have it turned on by a low current device.
Example: Use an HC-SR501 PIR motion sensor going to a Hex inverting buffer and then a MOSFET to turn on the SEN0539.
Such a scenario uses only a few mA instead of the SEN0539's ~50mA when idle.
I have that working fine now, but whenever the SEN0539 powers up, it broadcasts:
"You're welcome to use the voice recognition assistant".
This is untenable for my purposes.
Is there a way to disable this opening broadcast?
Thanks, Bob
