URM37 servo
userHead Adam.Po 2025-10-31 21:29:45 588 Views3 Replies
I bought URM37 v5.0 and I wont to control servo.
I send command RS232 0x22 0x12 … and on the servo output
I have only one pulse. To have more, I need to send command again.
but sending commad wich freq. 50HZ is impossible.
Is it possible to control servo in RS232 mode?
2025-11-01 23:19:08
Instead of driving the servo from the URM37, connect the servo directly to your MCU (Arduino, ESP32, STM32, etc.) and use a PWM output to control it.
Let the URM37 only handle ultrasonic ranging via serial.
userHeadPic ahsrab.rifat
Adam.Po wrote:
I know, it is possible, but I have bought it to control it only via serial interface. That's why I bought this expensive one. I could have bought a cheaper one, e.g., the HC-SR04.  Moreover, as I saw on the oscilloscope in PWM mode, the servo out frequency is 25Hz. My servo operates at a min of 50 Hz.
This circuit is a joke.
2025-11-02 06:13:09
2025-10-31 21:54:45
I forgot to mentioned that I use MG945 servo, it is typical, but it is not working below 50HZ (faster than 20ms)
userHeadPic Adam.Po
