Beetle esp32 c6 mini I2C didnt work on battery
Phuvis.Komutmas 2025-11-08 11:11:57 991 Views2 Replies When I first got the board, I²C (SDA/SCL) worked on battery power, but now it only works when connected by USB. The setup uses a Sensirion SEN66, W25Q64, and a DS3231 RTC. Battery voltage measures 3.7–4.1 V, so that likely isn’t the issue. I’d like to understand possible causes before buying a new board.
Before adding the RTC and flash modules, the board worked normally. After the issue appeared, I suspected the RTC might be the cause. If that’s true, how can I keep using it without running into this problem again?
2025-11-08 12:48:08
ahsrab.rifat
Hello, which product exactly? This one? https://wiki.dfrobot.com/SKU_DFR1117_Beetle_ESP32_C6
ahsrab.rifat Phuvis.Komutmas
wrote:
2025-11-08 14:54:43 1 Replies
Yes sir—exactly that one: DFRobot Beetle ESP32-C6
ESP32 / ESP8266 ProjectsESP32 TutorialsESP8266 TutorialsESP32 / ESP8266 ProductsIoT ProjectsIoT Products
.jpg)
