Edge101- DFR0886 Can not select board in Arduino IDE
userHead ANTONIOS.PSAROMPAS 2025-11-08 17:08:29 1150 Views4 Replies
Recently purchased a few units of Edge101 (DFR0886) and I am having trouble in selecting the board in Arduino IDE software.
I have installed the board as per product wiki steps No1-2-3- No4 (Step 4: In the search box, type "Edge101", locate the package shown below, and click Install. Wait for the download to complete, then click Close.) - all succeeded.
but when trying to select the board (Step 5: Finally, set the board to "Edge101 IOT Controller" by selecting Tools -> DFRobot Edge101 -> Edge101 IOT Controller.) although I can see the board , it doesn't select it !
Board is connected through USB ,LAN and also powered by 24Vdc.
Any help will be appreciated.
Thank you!
2025-11-10 03:35:51
I have removed all installed boards, even uninstalled Arduino IDE and made a new clean (deleted all Appdata folders) setup of the app, still the problem remains.
-DFRobot Edge101 menu is shown in boards menu, as also as Edge101 IOT Controller, but when trying to select it nothing happens. No board selected. I can only select COM port when I connect usb cable. Any ideas how to fix it? Thank you!
userHeadPic ANTONIOS.PSAROMPAS
2025-11-09 22:56:19
If you have multiple board packages installed (ESP32, STM32, etc.), there may be conflicts. Temporarily disable other board managers or remove their packages.
userHeadPic ahsrab.rifat
ANTONIOS.PSAROMPAS wrote:
I have removed all installed boards, even uninstalled Arduino IDE (v2.3.6) and made a new clean (deleted all Appdata folders) setup of the app, still the problem remains.
2025-11-10 03:39:10
