KIT0197-DFM8001 Configuration for 3.3V output
foIxDN 2025-11-13 23:02:28 681 Views1 Replies I am evaluating the KIT0197 for a ultra-low power project
I'd like to output 3.3V with a super-capacitor.
Here is configuration I've set
LDO Output voltage Vh = 3.3, Vl = 1.8
VCF[012] = 010 (changed)
H_EN = 1 (unchanged)
L_EN = 1 (changed)
MPP[01] = 00 (unchanged)
PRIM[234] = 000 (unchanged)
SCL_BAT = CAP (unchanged)
DCSC = 1 (unchanged)
PRIM_1 = 0 (changed)
Is this configuration correct?
As VCF[012] = 010 mentions “Dual-cell super-capacitor”, are the provided super-capacitors single- of dual-cell? Otherwise, how to connect a dual-cell super-capacitor?
The schematics refer to the connectors as J1..J19 but neither the Schematic.pdf and Dimensions & Component Layout.pdf mention those references. Could you please provide a document with the connectors numbers?
Thank you and best regards,
