TroubleshootingGravity
sen0257 incorrect data (half as much as in reality)?
userHead sergey.lebedev 2025-11-27 19:49:46 810 Views2 Replies
I purchased four sensors and began installing them on the heating system and water distribution system in a shopping center. I immediately noticed that the sensor readings differed from the readings of the analog pressure gauges already installed on the pipes.
2025-11-27 20:21:36
userHeadPic sergey.lebedev
sergey.lebedev wrote:
I wrote such a long post, but the forum won't display it :(
SEN0257 shows 325 kPa, but analog water pressure shows 6 ATM
I swapped the sensors, but to no avail.
I installed the next sensor in a new place and there is the same problem: it shows 250 kPa and the analog pressure gauge shows 4 ATM
2025-11-27 20:26:17
