Beetle ESP32-C6 Deep Sleep current too high
Marten.Sikkens 2025-12-12 20:55:25 2277 Views1 Replies I want to use The Beetle Esp32-C6 in a low power application. I have set the Beetle ESp32-C6 in Light Sleep mode and noticed 0.8 mA current drawn. For my application I want a lower value, so I changed to Deep Sleep mode. However, the current drawn is still 0.67 mA which is still too much for my application. I suspect the onboard charge LED, which is still blinking even in deep-sleepmode, to draw significant current. Could that be the case? And if so, how can I switch this LED off?
Thanks for your reaction!
2026-02-19 17:24:10
Adam.Watson
What voltage is the battery / supply you are testing with? check with a real li-po fully charges or 3.7v supply
Adam.Watson
