DC‑005 DC Power Supply Module — EasyElecModule
userHead john.hoghon 2025-12-22 11:00:36 10 Views1 Replies
The DC‑005 DC Power Supply Module is a simple and useful power input adapter board that lets you easily connect a standard DC barrel jack (5.5×2.1 mm) to your electronics projects. It provides a clean and stable power input point, making it ideal for powering breadboards, Arduino/ESP projects, sensors, and small circuits from a DC adapter or power supply.
👉 Key Features:
• Easy DC barrel jack interface for quick power connection.
• Converts the DC plug to a 2‑pin header that fits on breadboards or PCBs.
Compact board perfect for prototyping and testing.
• Compatible with common DC adapters (e.g., 5 V–12 V).
This module is great when you want to power your electronics safely and neatly without soldering the DC jack directly into your project.
Product Link:
👉 https://easyelecmodule.com/product/dc-005-dc-power-supply-module/
2025-12-22 11:19:12
https://easyelecmodule.com/product/dc-005-dc-power-supply-module/<a href="https://space-waves.co/">space waves</a> This link seems to be broken?
userHeadPic Karl.Walsh
