Unihiker K10 Face detection with Arduino IDE
Peter.Jacobson 2026-01-12 23:04:42 1241 Views1 Replies I received a Unihiker K10 last week. I ran through the factory demo and everything seemed to work fine. I started running through the "UNIHIKER Documentation Arduino IDE/Platform IO Examples" with the Arduino 2.3.5 IDE. Everything seemed to be working until I got to the AI Face Detection and AI Face Recognition examples. They never show the green detection rectangle. I wrote to techsupport@drobot.com for help. While waiting for their reply, I downloaded Mind+ and learned how to use it. The equivalent examples both worked fine using that platform. I took the Arduino sketch and loaded it into “Manual Editing” pane of Mind+, compiled and loaded it and it worked fine, displaying the green detection rectangle correctly. It also correctly demonstrated the error in the sketch: “Face Center Y” displays at Y=32 which should be Y=48.
So, there seems to be a library problem with Arduino?
support got back to me this morning and told me try here for help. I couldn't find the answer to my question, so if someone could point me to the appropriate post, I would very much appreciate it as I would prefer to use the Arduino
UPDATE
I heard back from support:
"This appears to be a core bug in the 0.0.3 BSP, which we will address in version 0.0.4.
As a temporary solution, you can downgrade the Arduino IDE BSP to version 0.0.2. Our testing confirms that the AI facial recognition feature functions correctly in 0.0.2."
Peter.Jacobson
