SEN0386 6-axis sensor seems to only run at 10Hz
userHead Johnsinski.69 2026-01-14 13:59:06 1081 Views5 Replies
I recently bought this sensor (SEN0386 6-axis gyro) and using the example sketch have gotten it to work. However is only seems to run at 10Hz. In the example the line:
sensor.modifyFrequency(FREQUENCY_10HZ);
should change the frequency but does not.
This results in a minimum loop time of 100ms which is way to slow for my needs. My understanding is I should be able to change it to 200Hz, among other speeds.
I see this seems to be a problem in other thread about this sensor, which I posted in but have not gotten a response.
How do I get different frequencies to work?
2026-02-16 14:56:39
Oh thanks guys, I will try your suggestions and see what happens.
userHeadPic Johnsinski.69
2026-02-10 07:29:53
An economy that continues to evolve through digital transactions, online businesses https://www.dfrobot.com/ and remote work environments, dependable financial services provide the clarity, organization, and professional oversight necessary to achieve consistent success, long-term growth, and lasting financial security in California’s dynamic and demanding marketplace.
https://allslotpkr.com/
userHeadPic Steve Micheal
2026-02-05 08:01:47
I'm working on project with this sensor (SEN0386).
I've the same problem with the frequency which I can't change. Did you find the way to fix it ?
userHeadPic Kitten23
2026-01-14 14:24:13
Hi Johnsinski! I’ve seen this issue pop up a few times with the SEN0386... It’s frustrating when the frequency command seems to be ignored :/
One thing to check is that on these sensors, the modifyFrequency command sometimes doesn't take effect immediately unless the sensor is 're-triggered' or the internal buffer is cleared.a common workaround that has worked for others is to call the frequency modification right at the end of the setup() and then add a small delay before the loop() starts…
Also, double-check if you are using the latest version of the library from the DFRobot SEN0386 Wiki. Sometimes the older example sketches have a hardcoded delay in the loop() itself—look for any delay(100) or similar lines that might be capping your sample rate regardless of the sensor's frequency setting.
If you've already tried that, try changing the frequency to a different value (like FREQUENCY_50HZ) and see if the loop time changes at all. If it’s stuck exactly at 100ms, it’s often a software-side delay or a serial baud rate bottleneck. Hope this helps you get closer to that 200Hz.
userHeadPic Oliver.Taylor
