Foam pads supplied with the CM4 IoT Router Carrier Board Mini with Metal Cooling Case
Ariën.Vijn 2026-01-21 22:43:22 643 Views1 Replies Greetings,
The IoT Router Carrier Board Mini with Metal Cooling Case (SKU: DFR0767-1) comes with two foam cushions. One smaller one that fits nicely the CPU on de CM4 module and conducts heat to the heatsink of the Metal Cooling Case. And a larger, thicker one that i cannot place.
What is the purpose of this foam larger pad? Where should i place that one?
Thanks in advance :)
2026-01-27 22:31:11
Ariën.Vijn
Support came back with a good answer:
"The thicker one is for the Raspberry Pi official CM4 CPU; the thinner one is for other CM4-compatible modules."
Ariën.Vijn
