How to Turn Off Google AI - Manual Settings To Disable
userHead monktechus 2026-01-23 13:02:34 12 Views0 Replies
Google AI is an automated feature of the Google search engine that someone searches for anything on Google, it displays a short, quick, and relatable response at the top position. It’s called Google AI. Know how to turn off Google AI, then explore this guide.
What Is Google AI and Where Is It Used?
Google AI is the integrated search feature. When you search for a query on Google, you get a quick answer at the top section; that’s Google AI. It’s used for quick answering without exploring SERP results.
Can You Really Turn Off Google AI?
Although there is no single button to press and turn off Google AI, but you can do so using the more tab on the SERPs. As you do it, you will only see the website link covering that topic, not the AI response.
How to turn off Google AI
To turn off Google AI, follow this:
Visit Google search engine.
Enter a keyword to search.
Select the more option under the search bar.
Pick ‘web’ only.
You will see only website links on your SERPs.
Final Say
You can easily turn off Google AI on your search engine by filtering out the searches. Know more here.
