Robot tracking like optical mouse with huskylens
UniDi.Com 2026-01-24 18:39:06 779 Views1 Replies Hi, is it possible to use huskylens to drive a robot.
It should deliver the x and y movements like an optical mouse.
So I can keep the robot in trace or move it in desired direction.
thank you
2026-01-30 03:47:41
Camila.67
Yes, it’s possible, but HuskyLens doesn’t work like an optical mouse. It gives object or line position data, not true X-Y movement. You can still use that info with a controller to guide the robot, keep it on track, or move it in a desired direction.
Camila.67
