Kit0139
Terry.Billau 2026-01-26 03:14:49 801 Views1 Replies Hello, I want to use Kit0139 hydrostatic sensor to measure the depth of effluent in a cesspit. Sludge sinks to the bottom with less contaminated water above it. Does any have experience of this? Can the sensor be lowered into the sludge and still function?
KIT0139 has a 316L stainless steel diaphragm, 304 stainless steel housing, and IP68 rating, so it can function in sludge (or viscous liquids). However:
1. Thick sludge/large solids may block the air tube or cover the diaphragm (impacting pressure transmission/accuracy, or damaging the sensor).
2. It measures total hydrostatic pressure at its position (total depth from sensor to liquid surface, not just "clean water" depth).
3. Install tips: Mount it in a stable area (use a guard/guide rod to keep it above thick bottom sludge, avoid agitation).
4. Density correction: Default code uses pure water density (1.0)—adjust for sludge-water mixture density (refer to the DENSITY_GASOLINE example in code).
5. Maintenance: Clean air tube/diaphragm regularly to keep them clear.
Conclusion: KIT0139 works in cesspit sludge if air tubes are unblocked and the diaphragm is not covered. Test first for thick/clumpy sludge, and adjust density settings for accuracy.
Yx Thank you very much for your helpful and comprehensive reply. What do you think about enclosing the sensor in a condom with some clean liquid in it?
