TroubleshootingArduino
Sensor wont initialize SKU: SEN0623
userHead cfletcher@strategic-moves.biz 2026-01-30 18:00:54 754 Views1 Replies
Re stopped initializing.
It has been working great for a couple of weeks, and all of a sudden the sensor simply wont initialize.
Any ideas
2026-01-30 18:49:12
Dear Customer,
Sorry to hear that your SEN0623‑C1001 60 GHz mmWave Indoor Fall Detection Sensor has suddenly stopped initializing after working well for a while.
There are a few possible reasons this may happen:
Power supply or connection issue – Please check that the sensor power supply voltage is stable and all wiring/connectors are secure. Temporary wiring loosening can cause the module to fail initialization.
Interference or environment change – If the sensor is used near other RF devices, large metal objects, or within a cluttered environment, interference may prevent proper initialization.
Firmware or communication issue – If the module was reset or experienced a communication error on startup, it may fail to start properly. Power cycling the host device and the sensor sometimes helps.
Hardware fault – Although rare, sudden hardware failure or damaged pins/connectors may cause the module to not respond.
To help us confirm the root cause, could you please provide the following:
• A photo of your wiring/connection setup
• The board/system you are using (Arduino/ESP32/micro)
• The serial output or error message you see when initialization fails
You may also send all details and photos directly to our technical support team at techsupport@dfrobot.com, and our engineers will assist you further.
Product Wiki (for reference):
https://wiki.dfrobot.com/SKU_SEN0623‑C1001_60GHz_mmWave_Fall_Detection_Sensor
We look forward to helping you resolve this.
Best regards,
DFRobot Team
userHeadPic DFRobot TechSupport
