Why don't the potentiometer terminals fit into the sockets on the Prototyping Shield or breadboard?
userHead Yx 2024-07-12 15:04:05 505 Views0 Replies
I have to say that I am loving the kit. I just wanted to let you know of an issue that I have encountered. In projects 11 and 12 of the kit, it requires the use of the 3 potentiometers. The problem is that the terminals of the potentiometers do not fit across into the sockets on the Prototyping Shield nor the provided breadboard. They are to wide.
2024-07-12 15:04:05 Hello, your feedback is very precious to us. Just as you said, the potentiometer couldn't be inserted to the hole easily, but with some strength to push it downward, it could be done. I've attached a picture about it. Btw, we will consider to upgrade it. userHeadPic Yx
