What should I do if the Cherokey's motors are not moving when only plugged in with USB power through the microcontroller?
Yx 2024-07-12 15:04:05 442 Views0 Replies What should I do if the Cherokey's motors are not moving when only plugged in with USB power through the microcontroller?
2024-07-12 15:04:05 Batteries must be connected to make the motors move! If the Cherokey is only plugged in with USB power through the microcontroller, the motors will be under powered and will not work!
Yx
Yx
