What is one reason the strip may not work?
userHead Yx 2024-07-12 15:04:05 377 Views0 Replies
2024-07-12 15:04:05 The code. Check if you have downloaded the code successfully. You can use the led connected with digital pin13 for the test or use the sample code Blinking. userHeadPic Yx
