If the Cherokey is only plugged in with USB power through the microcontroller, why the motors will not work?
Yx 2024-07-12 15:04:05 390 Views0 Replies If the Cherokey is only plugged in with USB power through the microcontroller, why the motors will not work?
2024-07-12 15:04:05
Yx
Batteries must be connected to make the motors move! If the Cherokey is only plugged in with USB power through the microcontroller, the motors will be under powered and will not work!
Yx
