I was able to scan the sensor address using the I2C scanner, but unable to initialise the sensor after uploading the sample code.
userHead Yx 2024-07-12 15:04:05 422 Views0 Replies
I was able to scan the sensor address using the I2C scanner, but was unable to initialise the sensor after uploading the sample code.
2024-07-12 15:04:05 If you installed the library from the Arduino IDE library manager, please remove it completely and download the library from this GitHub repo. And include the .zip library. userHeadPic Yx
