How to reduce power consumption when using a battery to connect the transmitter and sensor
Yx 2024-07-12 15:04:05 452 Views0 Replies When using a battery to connect the transmitter and sensor, how to reduce the power consumption as much as possible
2024-07-12 15:04:05 For some passive sensors, such as button, Collision sensor, magnetic sensor, connect the sensor The red and green wires to the transmitter, disconnect the black wire, which can reduce power consumption
Yx
Yx
