Can the Arduino read the digital I/O pin status of an XBee using the relay shield v2.1, considering XBee's 3.3V logic level?
Yx 2024-07-12 15:04:05 415 Views0 Replies With your relay shield v2.1 is it possible for the Arduino to read the status of some of the digital I/O pins of an XBee? Because the XBee is 3.3 volt there would need to be a logic level converter on the board, I believe.
