Troubleshooting
Abnormal sensor output after ambient noise collection
userHead Yx 2024-07-12 15:04:05 482 Views0 Replies
2024-07-12 15:04:05 Generally, you can troubleshoot by following these steps:
1. Check if the current ambient noise threshold is within the normal range:
If the threshold is higher than 50, it indicates potential interference sources in the environment; a preliminary check of the surroundings is recommended.
If the threshold reaches 99, it indicates strong interference; the sensor will likely fail to function correctly, and the output is prone to abnormalities.
2. In case of high threshold values, thoroughly investigate and eliminate environmental interference sources before re-collecting ambient noise to ensure the sensor output returns to normal.
userHeadPic Yx
