mmWave radar SEN0395 Arduino libraries & radar housing
userHead Erwin.Redl 2026-03-13 03:24:39 738 Views2 Replies
Hi there,
Arduino libraries tutorials:
I just started playing with the mmWave radar SEN0395 and Arduino. So far so good with some basic functions but now I am try to narrow the sensor detection area to a very narrow cone and seem to hit a wall. I am working with "DFRobot_mmWave_Radar.h" library which is supposed to allow me to set the detection range of 4 different areas. Somehow I can't get it to work. Somewhere I read you can also set the sensitivity of different areas and achieve the same effect.
Are there detailed tutorials about various mmWave radar libraries are is there information how the different detection areas are laid out by degrees or similar?
Housing:
I am also looking for outdoor rated housing for the mmWave radar SEN0395 module preferable powered by 24 VDC or a generic housing where I could put in a 24>5VDC converter and the mmWave radar SEN0395. I found a couple of files for 3D printing but I'd need something off-the-shelf…
Thank you for your help in advance!
Erwin
2026-03-13 18:03:44
Hi! The physical beam angle of the SEN0395 mmWave radar (100° horizontal, 40° vertical) is fixed and unmodifiable. You can only configure non-overlapping detection distance ranges via functions as instructed in the DFRobot official Wiki. Here is an example for reference:   https://community.dfrobot.com/makelog-313340.html
userHeadPic Yx
Erwin.Redl wrote:
Thank you!
2026-03-13 19:44:02
