SEN0604 Soil Moisture sensor capacitive measurement frequency question
userHead HHstein 2026-03-24 18:21:44 588 Views1 Replies
Hi there,
Hope you are doing well :-)
Can you please confirm if the SEN0604 high frequency for capacitive soil moisture sensing. (Above 60MHz). This is important as frequencies above 60MHz are more immune to soil salinity which would otherwise affect the measurement.
In the blog article: https://www.dfrobot.com/blog-17283.html?srsltid=AfmBOoqVL75uxUvxyiZd8wShmDCjxM8iw3sxKvQhjpklHxMPLwkn_MC9 after the section 4. FDR Soil Moisture Sensors (Frequency Domain Reflectometry) the recommended product is the SEN0604 which would suggest that this is an FDR sensor operating at high frequency but this is not specifically stated.
Can you please confirm if the SEN0604 performs capacitive soil moisture sensing at frequencies above 60MHz and is indeed classified as an FDR sensor? As I mentioned, the blog suggests that it is but does not confirm it.
Thank you and kind regards,
HHstein
2026-03-25 11:29:19
Hello!
The sensor is equipped with a high-frequency oscillation circuit and operates based on the Frequency Domain Reflectometry principle, which falls into the category of FDR sensors.
userHeadPic Yx
